-   -   clutch adjust 96 sl 1.9 ltr (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/clutch-adjust-96-sl-1-9-ltr-1811/)
BigSmitty Mar 14, 2008 06:27 PM
How do I adjust the clutch?Had recent tranny work done but now clutch pedal goes to almost floor before I can shift and even then every gear is hard to get into.Clutch was fine before this other work so it must need to be adjusted right?
Low Saturn Mar 14, 2008 07:14 PM
There is no adjustment for the clutch. Sounds like who ever worked on your transmission messed up the hydrolic assembly.
BigSmitty Mar 14, 2008 07:23 PM
Hey thanks for the quick response,I realized that it is hydrolic so I checked the fluid and it was very low.I added some dot 3 brake fluid and it seems to be coming out of it a little bit.How would he have messed up the hydro assy? Maybe I can look at it in the a.m. when there is light.Thanks
Smitty
