Check this out...
Saturn Custom supercharger Kit 1 9L Eaton M62 Polished New SC SL 91 99 SPS 95 96 | eBay
For those who wished they made an S series redline... Same blower as the ION and everything... |
I've seen it...talk about beautiful
I wonder if there's anyone gullible enough to just buy that, slap it on and expect much more out of their engine? I sure hope not.
What would the performance scene be without taking risk?
I'm taking a huge risk putting a 2.7 pulley on my redline with no head work and no bottom end work. It can be done, but we will see how good my cooling set up is. |
What is the issue with a 2.7 pulley? I'm considering doing one if I need to rebuild my snout... Maybe could add water injection too(no meth, just 10%isopropyl for anti-freeze)... After all, I do have the 80# injectors...
It will produce wayyyy to much heat to maximize its potential.
But if I can find a zzp stealth heat exchanger cheap, put the zzp s3 heat exchanger in front of that (complete overkill) I might be able to keep my temps low enough to hit a good number at the wheel. May have to move up to 80# injectors for that with a high volume fuel pump. Adding the water may be a good idea. I really want to figure out how to get 300 whp out of this damn m62. |
