when driving the car I here a sloshing noise in the car. i beleive its the drain for the air cond. whats the best way to drain(clear it) without alot of work |
Our Saturns have a one way drain valve to allow water condensation in the heater/air conditioning unit to drain out to the car; look around under the car by the firewall and you may be able to spot the small rubber valve. A pencil point or small tipped screwdriver might be poked into the valve lips to spread it apart enough to allow drainage.
| All times are GMT -5. The time now is 06:50 AM. |
