Newby here. I picked up a 95 Saturn SL 2 that now has 111,000 miles on it. The problem I have been having is the fuse to the cooling fan blows and then the car overheats. It hasn't been a real big problem yet, but with the warmer weather I know it will be. Has anyone had this happen with their Saturn? And what did you have to do to fix it? Edited by: sw2cam |
Unplug the fan and see if the fuse still blows. If it does, remove the relay and test again. If it still blows the fuse, check the wiring for shorts.
