Battery Charge Level Automatic Shutoff
Old Jul 30, 2015 | 06:49 AM
dwd375's Avatar
Default Battery Charge Level Automatic Shutoff
So I got the circuit design I will need for one of my more fun projects. I need another circuit to go along with it but the job of this circuit will be to automatically shut off the power outlet in my Saturn when it reaches a chosen voltage. This way I can leave something plugged in all night such as to charge, and have peace of mind the car will start up in the morning.
I will be modifying it some more to fit my needs but the base design is simple. Only requires one zener diode, two relays, two transistors, four resistors, and a variable resistor.
The final design of the complete circuit I use will be available to share should anyone want to make their own. I just might build a few raw circuit boards of it just for fun, maybe give to someone who wants to have it.
Old Jul 30, 2015 | 07:05 PM
dwd375's Avatar
I will likely install one that will control the outlets and another at a different trigger voltage to warn me of a low battery should anything happen on the road like the alternator failing.
Does anybody know what voltage the battery needs to be to start my cold 94 SL1 SOHC engine? I know about the safe range, but I also know it is not always true because it varies by engine size and temp and everything.
Old Jul 30, 2015 | 10:13 PM
I believe the charging light comes on on the dash if the charging system Output V drops below some voltage level. Should start w battery voltage near 12 (don't know limitations -- but what you're really worried about is whether the battery can deliver the required CURRENT to start the car, no?
Old Jul 30, 2015 | 10:26 PM
dwd375's Avatar
Yes. I want to make sure I know at what point is the battery reaching the bare minimum power left to start a cold engine.
Old Jul 30, 2015 | 10:59 PM
a battery can theoretically measure 11.5 V at rest (cold) but if it has a marginal cell that cannot supply its share of the total current, you won't know anything's wrong until you turn the key.
You'll then confirm by watching the V on the battery nose dive when you turn the key to start it that the battery cannot supply the required current at the requested V. So the battery (which measured ok V at rest) is actually history.
So to try to specify what voltage on the battery will still allow you to start the car seems a bit pointless.
I know it'd be nice to be able to make such a generalization, but personally I just don't think that is possible
This dude's opinion, anyway......
Old Jul 30, 2015 | 11:08 PM
dwd375's Avatar
That is a very good point. So then the circuit cannot be relied upon for a guarantee, nothing can. All it would do is help. Still, I'm going to build the circuit.
I value everyone's opinion, after all these posts are for discussion. There is only one thing I do not want to hear from anyone...
dwd375
Jul 29, 2015 10:35 PM
dwd375
Jul 29, 2015 10:16 PM
kvss.ravi
Mar 30, 2012 06:49 PM
jimmyslide
May 21, 2008 09:00 PM
90roadsterman
Jul 30, 2007 07:30 PM
