AC delco 21025102
Old Mar 11, 2025 | 09:38 AM
Holyman1973's Avatar
Default AC delco 21025102
I ordered spark plugs a few days ago from Autozone and their website list 21025103 as the correct plug. Looking at the RockAuto website the only difference I can discern is a slight difference in length. What I cannot find is a heat range on either of these plugs. Would there be a big difference since they are only one number off each other? 94 sl2.
Old Mar 11, 2025 | 11:41 AM
Just return them.
I'm confused how you ordered the 02 as the AutoZone web page for a 94 SL2 lists the correct ACDelco part number
AC delco 21025103,
which matches RockAuto.
And the 02 plug is not for the SL1. No idea what it's for.
Check your invoice.
These cars are very finicky with respect to the ignition system. At least they can be. The NGK 5643 is the identical plug which used to be cheaper but isn't anymore. How about that.
Old Mar 11, 2025 | 12:23 PM
I ordered the 03 not the 02.
Old Mar 11, 2025 | 11:03 PM
The 03 is the correct part number so there is no issue.
To convince yourself, go back to the AutoZone site and the RockAuto site and check. They are both the 03.
You are good to go, unless they sent you the wrong plugs.
fabricgator
Feb 5, 2025 12:29 PM
Apr 4, 2016 06:40 PM
02saturnsl1
Dec 12, 2013 07:38 PM
U_turn
Sep 6, 2005 03:30 PM
