How bad is the fender? Is is destroyed or only cracked? if cracked you can repair it with sema tape and sema quickset dual mix. I have repaired my sons with it and i will paint it later this summer, after an engine rebuild and clutch change.
sema? what is this sema and where do I find it? How does it work? is it an epoxy resin deal?
Please do elaborate. Can it be used for general body work or is it more like the equivalent of drywall tape and joint compound? |
Some type of resin expoxy.
I used this with the reinforcement tape. Dual-Mix? Quick Set 50 Products | SEM Products Here is a video, i also used the same mix to repair a crack. I drilled zig zag small holes i the cracks and at the end of the crack and filled it and used the reinforcement tape on the back of the fender.( it looks like fiberglass drywall tape. i bet you could use that). https://www.youtube.com/embed/kd-jXU9_gS0/ |
Thanks for the additional info.
spasm --- can you pls config your signature to look like ours? First name/location (state) year model mileage of all saturns any other vehicles you feel like listing go to your username at top right of page click username>>userCP>>select Edit Signature on left side. Thanks |
I bought the materials off amazon, less expensive than other places.
