I have an engine lag that will sometimes kill the engine when the ac on at a complete stop, when i accelerate from a stop the ensometime lags then dies, i have replaced the egr, knock sensor, map sensor and idle position sensor, also replaced the throttle positioning sensor, any gueses as to what to look at nextEdited by: manarlican |
did you do a tune up? if so then replace the coil packs
| All times are GMT -5. The time now is 08:58 AM. |
