99 motor swap?
I have a 99 saturn sl1. My motor is blown. I have acess to a 95 SOHC motor,
Iv read these are interchangeable. According to this link http://www.saturnwiki.net/index.php/Swap_Guide the injectors are different. Do i just swap intake manifolds to fix this? Any other issues ill run upon? |
Yeah that set up will work, you just have to swap over the intake manifold/injectors over. Make sure you also update the intake manifold gasket because it will leak coolant if dont
ummm, early 95 is ODB1 and 99 is ODB II so may have PCM issues.
also, isn't the fuel rail different from 1st gen to 3rd gen. Sorry I don't have all the answers for you -- search other forums for saturn swap info. Low Saturn could tell you --- maybe contact him over at differentracing.com? |
Couldn't remember where I had seen this but finally found it again while looking for something else...
http://www.saturnfans.com/forums/showthread.php?t=88699 enjoy |
| All times are GMT -5. The time now is 08:36 AM. |
