-   -   ’98 SL2 Delay reverse/ stuck gear (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/98-sl2-delay-reverse-stuck-gear-437/)
gomoose May 3, 2006 08:23 PM
I have a '98 Saturn SL2 and it has an automatic transmission. Every time I put it in reverse, there is a 3-5 second delay until the gear engages. It's worse when I'm on a steep hill; I have to pedal the gas in order to engage. Also, sometimes, when I get on the freeway, the car gets stuck on low gear, reving up my RPM to almost red. It doesnt seem to shift to higher gear. I usually pull over, turn off the engine, and turn it back up hoping it engages. This happens occasionally. I checked my transmission fluid and it seems to be OK. Anyone have any ideas and suggestions?
derf May 4, 2006 01:48 AM
See related post under "general tech help"
