-   -   '97 saturn sw2 automatic (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/97-saturn-sw2-automatic-10656/)
Tu MadRe Jun 21, 2016 02:37 PM
http://www.rockauto.com/info/232/232...FF_S8208_1.jpg
hey I'm new here and I love my new car for $600, 154xxx! '97 saturn sw2 wagon automatic. Anyways I'm having problems since im throwing some code on the ob2 scanner of p0717/16 and I'm hearing my problem is my turbine speed sensor. (i was throwing p0420 but that went away I HOPE). -However I'm trying to place an order to purchase a brand new turbine speed sensor from rock auto and I like to know if I type in turbine speed sensor.. am I buying the correct part? I ALSO poSTED a photo of the part. Thank you
derf Jun 21, 2016 10:05 PM
see
P0716 and P0716 - SaturnFans.com Forums
for P0716 /P0717. you may not need to replace it.
IF you do, get the AC Delco or Standard Motor Products
____________
P0420 catalyst below efficiency threshold
If your catcon is gone, this code is not going away on iis own.
Sometimes the rear O2 sensor can get poisoned and cause erroneous readings.
If you choose to do the rear O2, go with the Denso version of the OEM part
Tu MadRe Jun 22, 2016 10:18 AM
Originally Posted by derf (Post 54941)
see
____________
hey!!! thank u for letting me know something. however I was following the right and correct information when I cleaned the turbine speed sensor this past Sunday with electrical cleaner spray and after putting everything back together? engine service soon light pops on every 5 seconds laters after i clear the 716/717 code. so I had to ask.. and now you told me the info I wanna hear! I'm not gonna wait anymore or decide to mess with it. every thing under $100 shipped to the HUT! Anyways but you said THE Rear o2 sensor? cause I'll ask for a rear o2 SENSOR when I call up rockAUTO and place my order so I can make sure I'm ordering the acurate correct part.
Thank you so much!!!
Jesse Shaw Sep 4, 2020 06:47 AM
Originally Posted by Tu MadRe (Post 54935)
https://www.rockauto.com/info/232/23...FF_S8208_1.jpg
U have the right part i have the same car as u do i had that problem a about last year as soon as i replaced the bad speed sensor and put a new one in my car was just fine.
so u r good.
