-   -   97 Saturn SC2 Power Steering issue (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/97-saturn-sc2-power-steering-issue-8132/)
lazyman Jul 19, 2013 06:05 PM
Help please.... Sorry this car is a 1999, friends car.... my wife totaled my 1997! OOPs
So I just changed out the power steering pump. It has the EVO on it and I swapped the parts and everything pumps.... except there is no power steering! I disconnected the electrical plug on the back of the pump and it is supposed to read 12 volts. It is only reading 7.8 volts. Is there a fuse or something that is tripped or blown? Or what is going on with this issue? Any help will be greatly appreciated....
Thanks Eric!
Paul b Jul 19, 2013 06:17 PM
It might just be air in the lines I have never done a power steering pump on a saturn before but on all the rest of them I have done you have to turn the wheel from stop to stop 3to 4 times to get the air out with the engine running.
lazyman Jul 19, 2013 06:58 PM
No air in the line... I did bleed the system and got the air out of the line. It is an electrical issue, not the fluid....but thanks for the input.
Dtruck1 Jul 19, 2013 09:21 PM
Says the guy measuring 7.8 volts and thinking it is a blown fuse. Blown fuses read no voltage potential meaning 0 volts. That is my input.
OceanArcher Jul 19, 2013 10:37 PM
I'm confused -- Saturn didn't start using electrical power steering pumps until 2003 ... I thought ??
Paul b Jul 20, 2013 08:00 AM
My 1999 has a regular looking pump on it now it does have a wire going to it that I assume ( I might be wrong ) is for a fluid level sensor.
lazyman Jul 20, 2013 11:02 AM
This 1999 has the EVO.... Electronic Variable Orifice on the power steering
