97 s series DOHC cluster
i was tryin to find a cluster different from the stock cluster but cant seem to find one .... any1 got ideas on where to find one??
'or if i can just get my needles to light up so i can see where im at in speed because i only travel at night and even wit the light settings turned up i still cant see the needle.... any ideas on that??
Sounds like you might need to replace a few bulbs in there, I can see my needles perfectly when turned all the way up.
Ive looked around and the only things i have seemed to find were white faced gauges. And even then I dont know how easy that is to get at this moment. I remember seeing an LED swap guide on sixthsphere or one of the other saturn forums, but I have seemed to misplaced the link.
If anything - go to pepboys and pick up an LED strip/ LED lights and mock them up to light your dash.
Normally theres a light strip along the top of the gauges, which shines down and illuminates the needles.
However, I noticed your odometer isnt digital, so there might be something different btween years. (probably not though)
This is a video i put on you tube to show a problem but you can get a good look at how the gauges are suppoded to light up.
http://www.youtube.com/watch?v=yGSyAT-nZNg
