< src="http://www.google-analytics.com/urchin.js" =text/> </> My '96 SL1 has an idle issue maybe one of you have seen before and can help me with. When warm, it idles right at 750 RPM, like at a light or stop sign. Sometimes, it'll flucuate up or down 50 RPM's and then stall. I can restart it, but it takes longer than if I was starting it cold. Any ideas here?? Could it be the idle air control valve?? Thanks!! < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
Im having the same issue!! Have you found out anything or have you fixed
the problem. If you have any advice it would be really appreciated!! |
hey i got the Sl2 running you might want to take your Idle air control valve
off and clean it out with soon carb cleaner or something of that nature. Also check for vacuum leks. if that doesn't work do the same thing to the egr valve and install a new gasket. That should work for you. |
< src="http://www.google-analytics.com/urchin.js" =text/> </> Will do!! Thanks for the suggestions! < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
< src="http://www.google-analytics.com/urchin.js" =text/> </> I have a 96 sl1 also, im almost possitive it hase nothing to do with the air, plus that gets expensive. Try the FUEL FLITER. it runs about $30at kragen. i guarentee you have never changed it, and considering it is a 96' it has been a long time. Try it out let me know, Lates Jay < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
| All times are GMT -5. The time now is 03:40 AM. |
