ok i scanned my car today and got a few codes..here all is wrong with my car..no power windows, ac clutch does not turn on, no sunroof, no rear defrost and the most recent problem the engine coolant gauge drops and the car runs like crap, it dies, revs up really high in park or neutral. the codes i got were P0118 Engine Coolant Temperature Circuit High Input P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0141 O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2) P1651 Fan Control 1 relay or QDM "B" fault P1650 Driver 2 Input Voltage High P1599 CC Power Management mode engine stall P1115 ECT circuit intermittent high voltage P0711 Transmission Fluid Temperature Sensor Circuit Range/Performance P1620 Low coolant circuit any suggestions are very appriciated [img]smileys/smiley17.gif[/img] |
For the engine coolant sensor the old one is resin tipped, prone to cracking, requiring replacement with a brass one. Here's a picture procedure; http://www.saturnfans.com/forums/showthread.php?t=37884. |
