-   -   96 saturn engine into a 94? (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/96-saturn-engine-into-94-a-2544/)
Ryan31783 Oct 16, 2008 01:22 PM
I am thinking about buying a 94 4 door saturn with a siezed engine to fix and sell, I was wondering if an engine out of a 96 4 door would bolt up or not? Sorry if this is a pretty vague question, I don''t know the first thing about saturns, all i own is toyota''s
TIA
Ryan
Low Saturn Oct 18, 2008 10:57 PM
Yes.
Use the 1994''''s original intake manifold, fuel rail, injectors and throttle body. You''''ll also need to drill and tap a hole for the second temperature sensor found on 1991-1995''''s. The neck where the upper radiator connects to the head is a perfect spot.
This is assuming you''re talking about a DOHC (SL2, SC2 or SW2). If its a SOHC, then forget about it.Edited by: Low Saturn
