soo i have changed my pcv valve 3 times already within the last 3 weeks and every week i check it just keep getting filled up with this gold color gunky stubstance.. how do i prevent this from happening ??? Edited by: sw2cam |
Pull the camcover off the engine and thoughly clean the inside of it. Then you might want to run a half bottle MMO in the engine a few minutes before your next few oil changes to clean the gunk out.
Then change the oil more frequently and dont use cheap oil. |
how does that stuff happen man and what is mmo Edited by: sw2cam |
From dirty nasty oil.
MMO is Marvels Mystry Oil http://ecx.images-amazon.com/images/...2L._AA280_.jpg |
could this also be caused by in the sumer i was running i was running 93 octane but now iam back to87 for the winter to save money could this have something to o with it ?? Edited by: sw2cam |
Nope, and it has nothing to do with using winter air in your tires.
hey low saturn i found some of that mmo now how much should i use and i should pore it in my oil or gas or both thanks man
I think I remember reading you can use it in either gas or oil (a long time ago), but I'm pretty sure he meant to put it in the crankcase.
Dump half the bottle in, let the engine run for a few right before your next LOF to clean it out a tad. |
what is a lof
