95 sl wont start
changed fuel pump and filter but seems like fuel not getting to fuel rail, could it be TPS or pressure regulator? will run while spraying starting fluid in throttle body. have spark and good fuel pressure at test valve???
OK -- why do I feel like I have missed the first thirty minutes of this movie?
What error codes are set (if any)? Have you checked fuses both under the hood, and inside the vehicle? What pressure are you seeing at the test valve? |
