i have a 95 sl 4 door. doch 2.0. runs great and everything but i have a oil problem theres no leeks or anything so it must be using it somehow. i have to had about 2 quarts of oil per tank. can you guys help me out
Can't help you -- but can explain what's going on:
The engines on the S cars are notorious for burning huge quantities of oil as the mileage gets above 110K (on average). The oil control rings wear and/or seize in place at the top of the pistons, which allows oil to leak past the rings and get into the combustion chamber, where it is burned along with the air/fuel mixture. The valves are also probably not sealing well as the seals are worn -- again letting oil into the combustion chamber. The valve guide seals (valve guides guide the motion of the intake and exhaust valves) are also probably worn -- yes, more oil getting into the combustion chamber. If you're going to continue to drive as is, do not let the oil get down by more than 1/2 to 3/4 of a quart. These engines only hold 4 1/2 quarts total -- so 2 quarts low is driving with almost half the oil missing! You are greatly accelerating the wear on your engine..... ____________ Having had a 95 DOHC partially rebuilt by Saturn to address this same issue, I can state from experience that it is probably worth the extra $$ to put a factory remanufactured engine in (if you refuse to part with your Saturn and intend to keep the car indefinitely) vs having it rebuilt. If you do choose to do a partial rebuild, do the rings and replace the cylinder head with a remanufactured one (I did not) -- you should </span>end up with a car that burns very little oil -- versus one that eventually returns to consuming oil -- but a steady, fixed amount (my 95 -- still running -- 182K+) -- once the rest of the seals (valve guide seals were not replaced in my case) continue to wear. |
all i say is live with it and keep putting the oil in it. ill bet
almost everybody in this forums burns a little bit of oil, including me |
I have a 95 SL2 with 99Kand changed the oil today. It smelled likeburnt oil. I change it regularly, (3k)....... It's normal....[img]smileys/smiley4.gif[/img] |
my sl2 has 143000 and doesn't burn an oil. I have herd that using synthetic will usually cause it to burn less oil
| All times are GMT -5. The time now is 08:31 AM. |
