'94 SL Sedan double over-head cam A/C and Radio went out at the same time. I've checked the fuses and they're ok. Any way to check where the fuses plug into to? Any other ideas? |
I see in haynes that both fuses are in the interior fuse box - radio and hvac - #1 I would check to see if anything else controlled by that fuse box is acting up - maybe a ground is bad - it's in a tough spot for tracing where the wires go, so that's why I asked if anything else is acting up as it will be a job.
The only common item between the radio and the ac is 1st the fuse box |
| All times are GMT -5. The time now is 03:08 AM. |
