-   -   93 Saturn SL2 Warning Beep (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/93-saturn-sl2-warning-beep-3192/)
jkell65 Apr 23, 2009 10:20 AM
93 Saturn SL2 continues the warning beep, when I open the door, even though the keys are out of the ignition and the lights are off. Just started a couple of days ago, and consistently does it all the time. Curious if anyone has an idea where I can start looking...perhaps it's a fuse or something with the ignition. Thanks :confused:
OceanArcher Apr 23, 2009 09:28 PM
The sensor inside the key switch assembly that triggers when the key is still in the lock is broken
derf Apr 23, 2009 10:14 PM
sometimes it just gets jammed up in the position that it would be in if the key was there -- if you jiggle the key in the ignition you may be able to get it back the way it should be.
Or, like OA said, it's broke and will chime forever. I think there is some other important/useful stuff that shares the chime fuse, so check the owner's manual before you just go and pull it....
GMunny May 3, 2009 02:50 PM
I have the same issue, but its been going on for over a year.
