5 speed swap questions
Old Mar 17, 2010 | 12:22 PM
silver04saturn's Avatar
Default 5 speed swap questions
I am in the process of doing a five speed swap on a 2002 sl2. The donor is a 97. I have most everything finished but had some questions.
-for the reverse lights and neutral/clutch pedal switch which wires under the hood do I connect to these. I read the its the green and blue but there are several green wires.
-the ignition switch will not turn and the steering wheel is locked. There was a cable that ran from the auto shifter to the ignition and I messed with that and still couldn't get it to turn.
-I am having a problem getting the left axle to lock into the transmission. I've tapped it shoved it, etc and it won't lock into place.
Any help would be apprciated. Thanks.
Old Mar 17, 2010 | 04:16 PM
Hello and welcome to the forum
Octavious
Apr 23, 2012 07:56 AM
Engine & Internal
May 15, 2010 12:11 PM
May 15, 2010 12:09 PM
May 15, 2010 12:06 PM
