200xxx mile check up
i will be hittin 200xxx miles this week the car will be due for an oil chage and i want to do a good look over on the car... any sugestions on aything i should check out
flush brake fluid/bleed system (every 100K)
flush coolant system (if you haven't recently) clean EGR and ports (if you haven't recently) check coolant hoses under the hood (while engine cold) -- make sure they are still pliable and do not show signs of cracking I'd say check exhaust but you just did work on that, no? |
| All times are GMT -5. The time now is 08:43 AM. |
