2002 SL2 Air Pump and EGR
Old Jan 18, 2025 | 11:49 AM
Saturn Addict's Avatar
Default 2002 SL2 Air Pump and EGR
Originally Posted by Saturn Addict
Greetings Saturn Brethren.
I find myself using saturn SLs as daily drivers. It's a habit I've fallen into over the last 15 years and at this point I have surrendered to it. I find myself with a very unhappy 2002 SL2 and have come to beg for guidance. When I started it up after sitting for a while, it struggled to turn over and I got a huge white cloud of exhaust. I did a code dump and have P0133, P0410 and P0440. Before I started tackling these one by one I wanted to ask if this could all have a common cause. Sorry to charge in with questions :-/
Thanks for your help!
Progress! The wonderful EGR system diagnosis video that gets posted here showed me that my air pump isn't running and the vacuum solenoid isn't opening. Gonna start with air pump and go from there.
Old Jan 18, 2025 | 02:36 PM
Welcome and please continue in the S series section.
Andy
Old Jan 18, 2025 | 04:24 PM
And voila,
Now he will.
​​​​​​One day I'm going to lock all those stickies after cleaning out the crap posts.
Old Jan 19, 2025 | 12:40 AM
DropDead's Avatar
And voila,
Now he will.
Why
5char
Old Jan 19, 2025 | 11:26 AM
Many thanks to the mods.
Had to get the car out of limp home mode, then found that the secondary air injection valve had failed. Could that cause all those codes?
Old Jan 19, 2025 | 09:02 PM
If you know it failed, replace it, clear the codes, drive it and see what comes back.
We can guess til the cows come home (if they even do) but it doesn't change the next step so replace it and then we'll know
Old Jan 20, 2025 | 02:36 PM
It's replaced. Now we wait.
Old Jan 20, 2025 | 05:26 PM
Does the electric air pump run on cold start now? I have the same system on my 2002 L200/5. I have also had to replace the check valve.
check valves let exhaust flow back into the pump and can damage them. The pcm looks for pump operation and solenoid action to help cold start cat warmup. The system is designed to get the car in closed loop as soon as possible. The check valve failure may have damaged both the pump and the solenoid.
Brand209
12
Oct 14, 2019 11:11 AM
RKelly5327
Sep 25, 2017 06:18 AM
stormie
Feb 12, 2016 01:15 AM
cdrematt
Jun 29, 2015 10:52 AM
calvintanner
Aug 1, 2009 06:37 PM
