Ok my DRL are staying on when i shut my headlights off, shifter in park, car off. I removed the DRL relay and DRL were still staying on? when i put the relay back in and shut the hood the DRL went out. Any help would be greatly appreciated.
this site sucks, no one''s answering us
check the voltage of the pwoer wire when the car is off. If it''s getting power then trace it back to the battery or fuse panel
Check the wire to the right side high beam headlamp. Look for cracks/breaks in the insulation that might be grounding to the metal chassis of the car. Examine all the way from the fuse block to the light ....
