2002 SL "Service Engine Soon" came on?
Old 02-19-2007, 02:52 PM
motmmp247's Avatar
I have a 2002 SL & the "Service Engine Soon" light has come on, after reading some of the posts on this & other websites, I wonder if anyone can point me in the right direction. Thanks.
Old 02-19-2007, 07:20 PM
Go to Autozone or similar and get codes read for free. Write down the actual codes (Pxxxx) and post them here -- we'll help you sort through them.
Derf
Old 02-20-2007, 01:53 PM
group_raider's Avatar
I have the same problem. Is you car running rough or does it feel like a piston is mis-firing?
Old 02-21-2007, 03:43 PM
motmmp247's Avatar
The error code reading was as follows
P0128 "coolant temp below thermostat regulating temp"
If anyone could point me in the direction as to what needs replacing or servicing I'd appreciate it. Thanks again guys.
Old 02-21-2007, 04:16 PM
Your thermostat has gone bad. Replace it. It can be done from thetop, and if you have a decent wrench and socket setthis repair should cost less than $50.00
Old 02-21-2007, 10:48 PM
motmmp247's Avatar
Hey group_raider thank you for the advice, I picked up & changed the thermostat, all is well. Thank you, & God bless all of you.
Old 02-05-2008, 07:29 AM
flattfoot's Avatar
</>I also have a 2002 SL1 and the service engine light came on.
I had the codes read and was told that they were:
P0301 and P0507
Can someone tell me what they are and if I should have the codes reset? Edited by: flattfoot
Old 02-05-2008, 06:33 PM
original007's Avatar
leaking intake gasket.#1 misfire and high idle code. spray carb cleaner near intake gasket by the p/s pump area u will notice a change in rpm.just to verify
Old 02-06-2008, 08:43 PM
keith's Avatar
I agree, had the same code P0507, and it was the intake manifold gasket.
Old 02-06-2008, 10:17 PM
mchevy76's Avatar
</>Sorry to hijack your thread but I had Autozone read mine and got cylinder #1 misfire. I changed plugs and wires, What else could it be?
Mike <!--
var SymRealOnLoad;
var SymReal;
Sym()
window.open = SymWinOpen;
if(SymReal != null)
SymReal();
SymOnLoad()
if(SymRealOnLoad != null)
SymRealOnLoad();
window.open = SymRealWinOpen;
SymReal = window.;
window. = Sym;
SymRealOnLoad = window.onload;
window.onload = SymOnLoad;
//--></>Edited by: mchevy76
Quick Reply: 2002 SL "Service Engine Soon" came on?
