2002 saturn sl2, ingnition, security light on, no start
Old Apr 3, 2024 | 09:59 AM
Mirsad679's Avatar
Default 2002 saturn sl2, ingnition, security light on, no start
hello
My saturn steering wheel and ignition locked, so I jurked it and finally turned the key all the lights started flickering, I removed ignition cylinder and my buddy put it back in the the housing, and everything locked again so we drilled it but still cant get it out, Ill have to remove steering wheel to get it out. Coyld All this couse a passlock to come on and not let me start the vehicle.
I need help here.
Thank you
Old Apr 4, 2024 | 12:44 AM
Yes. There is a passlock 2 sensor in the ignition switch. It must sense the correct key in the ignition or the security system is activated. If the sensor was damaged or the key is not being detected, the security system activates.
If you disconnected power to the ignition switch, the security system likely needs to relearn itself and synchronize communications between the different parts.
Once you have a functional ignition switch and functioning cylinder, you will need to do the GM passlock relearn.
I suggest you do the 30-minute version up front. Follow the steps exactly as written. Ensure your battery maintains it's charge during the entire procedure or the procedure will fail because the electronics will not be functioning properly.
If you need to replace the ignition switch, you must be sure to purchase a compatible one with the passlock sensor in it. The system will relearn properly with a different key and a different ignition to the best of my knowledge. Though having the ignition cylinder rekeyed would be much more convenient.
Old Apr 4, 2024 | 01:31 PM
grcauto8453's Avatar
Home >> Saturn >> 2002 >> SL2 L4-1.9L DOHC VIN 7 >> Repair and Diagnosis >> Steering and Suspension >> Steering >> Steering Column >> Service and Repair >> Ignition Lock Cylinder
REMOVAL
IMPORTANT: If ignition lock cylinder is replaced, Passlock relearn procedure must be performed. Accessories and Optional Equipment/Antitheft and Alarm Systems/Service and Repair/ Service and Repair
1. Disconnect negative battery cable.
2. Remove lock cylinder bezel from steering column shroud by carefully prying with thin bladed screwdriver.
3. Remove shroud fasteners and remove steering column upper and lower shroud panels.
4. Insert key into ignition lock cylinder and rotate to RUN position. Then rotate the ignition cylinder back to the ACC position.
5. Depress the locking button on the side of ignition module assembly with a thin pick-type tool. Slide lock cylinder assembly from ignition module.
INSTALLATION
IMPORTANT: Actuator blade within ignition module housing must be in the ACC position to install lock cylinder assembly. If rotated, replace it to the ACC position using needle nose pliers.
1. Insert key into ignition lock cylinder and install into ignition module.
2. Install steering column upper and lower shroud panels and shroud fasteners.
3. Install lock cylinder bezel.
4. Reconnect negative battery cable.
Old Apr 4, 2024 | 03:21 PM
As I suspected, you will have to do the relearn procedure.
That charm stuff is pretty nice. I need to investigate it..
Here's a link to a sticky on our site that explains Passlock 2 as well as the actual procedure. They're kind of blended together. The relearn procedure for GM is all over the internet so you can find it elsewhere if you hate my write up
https://www.saturnforum.com/forum/ge...ocedure-12031/
Old Apr 4, 2024 | 07:15 PM
Mirsad679's Avatar
Default Passlock security, ignition
Ok that you for a quick reply.
I thought about going on a junk yard and get a ignition housing since its so hard to find one, and get the ignition cylinder hopefully will.find the key if not Ill ask locksmith to make my key work with ney cylinder. When releRning the passlock do i need to try start the car and let go just first time or all three times?
thanks again
I did disconnect the ignition switch, tried ro hot wire it lol. Didnt work.
Old Apr 4, 2024 | 08:47 PM
You will need to repeat the 10 minute cycle three times, it will start on the fourth try. You must follow the procedure exactly as it is written.
Old Apr 4, 2024 | 09:49 PM
Mirsad679's Avatar
Default Saturn
Ok. Once I get complete housing assembly, I will install and try it from there. I will let you know how it goes. Made a huge mistake drilling the cylinder I could've coded new cylinder using old one. 😀
Old Apr 4, 2024 | 11:38 PM
If you take the title and the person whose name is on the title to a GM dealer, plus your driver's license etc, they can give you the key code for your vehicle. You then need to take your new ignition cylinder and the key code to a locksmith and have them repin it.
The alternative is to reverse engineer the pins by putting the key into the cylinder without the pins in place and, by trial and error, putting in the correct height pins such that the top surfaces of each are at exactly the same height and fit into the ignition switch exactly. This will allow the key to turn when they all get displaced by the key that is inserted. I've seen people rekey by trial and error in under 10 minutes. I know it would take me hours. Once you get the feel for it apparently it becomes child's play. Personally I would fork out the $50 plus the key code to a locksmith. And of course that would be before you install it because well just because.
Old Apr 5, 2024 | 01:05 PM
Mirsad679's Avatar
Default Saturn
Sweet. Ill probably do that, once I get home,I will work on it and also does it matter if I take it off auto matic or manual. Mine is manual and 2000 to 2002 sl. should be all good. Correct?
thank you for your help. To remove air bag and steering wheel battery has to be completely disconnected?
Old Apr 5, 2024 | 10:24 PM
Do a VIN based search for OEM replacement parts on a GM website to ensure that the same part number for the ignition switch and cylinder was used for 2000 to 2002 and for both manual and automatic. Don't assume because you know what happens when people make assumptions.
As for airbag safety, most vehicles have an SRS backup battery with charge maintained from the main battery. The backup battery is there so that if the vehicle that has been in a frontal crash and had its battery connections severed, the airbags will still be triggered should additional collision with the vehicle occur. Usually they last about half an hour. So after you disconnect the battery, the main battery, wait at least a half hour longer for the backup battery to drain.
I don't know that Saturn's had the backup batteries, I'm just playing it safe for your sake. You can look up and see if they existed in those cars or not. I've never looked. Today's cars, I think the answer is universally yes
