Hello new to the forums so Hello all[img]smileys/smiley2.gif[/img] I was wondering where the fill and drain plugs are on a manual transmission and how much fluid goes in... Help is appreciated[img]smileys/smiley1.gif[/img]
usually the owners manual will tell you
Ha ha I wish.... Newer cars want you to take it to a shop and get the work done there. Its not in the owners Manual.. Mabie to fill an auto transmission.
You pull the dipstick and fill it there, Its located behind and below the battery. Kinda under the brake master cylinder. http://www.differentracing.com/mike/...antransdip.jpg The drain plug is under the car (obviously). http://www.differentracing.com/mike/...transdrain.jpg |
Ha ha yea I found it earlier today.... Thanks. I knew where the drain was but not the fill. When I found it earlier I accidentally Wiped off the dirt and crud that was built up over the years; and You could Barely see it and no red was showing. I was looking for a bolt but then When I seen a tint of red and wiped it down more I figured it out.
You said
"I was wondering where the fill and drain plugs are" Then you said "I knew where the drain was " Then you said "Ha ha yea I found it earlier today" I don't understand why you asked before you looked. Edited by: sw2cam |
I did look but the fill plug was covered in black gunk and I didn't see it... Like I said. Also I was looking for a bolt not a red plastic thing.
| All times are GMT -5. The time now is 08:41 AM. |
