2002 Saturn SL1 Transmission
Old Oct 16, 2007 | 11:56 PM
thebigbluecan's Avatar
Hello new to the forums so Hello all[img]smileys/smiley2.gif[/img] I was wondering where the fill and drain plugs are on a manual transmission and how much fluid goes in... Help is appreciated[img]smileys/smiley1.gif[/img]
Old Oct 18, 2007 | 11:39 AM
rabobanks's Avatar
usually the owners manual will tell you
Old Oct 18, 2007 | 07:57 PM
Ha ha I wish.... Newer cars want you to take it to a shop and get the work done there. Its not in the owners Manual.. Mabie to fill an auto transmission.
Old Oct 20, 2007 | 11:27 AM
Low Saturn's Avatar
You pull the dipstick and fill it there, Its located behind and below the battery. Kinda under the brake master cylinder.
The drain plug is under the car (obviously).
Old Oct 21, 2007 | 01:39 AM
Ha ha yea I found it earlier today.... Thanks. I knew where the drain was but not the fill. When I found it earlier I accidentally Wiped off the dirt and crud that was built up over the years; and You could Barely see it and no red was showing. I was looking for a bolt but then When I seen a tint of red and wiped it down more I figured it out.
Old Oct 21, 2007 | 08:07 AM
You said
"I was wondering where the fill and drain plugs are"
Then you said
"I knew where the drain was "
Then you said
"Ha ha yea I found it earlier today"
I don't understand why you asked before you looked.
Edited by: sw2cam
Old Oct 23, 2007 | 02:42 PM
I did look but the fill plug was covered in black gunk and I didn't see it... Like I said. Also I was looking for a bolt not a red plastic thing.
Alberto
Nov 2, 2008 08:52 AM
jizake1jz
Aug 3, 2008 09:46 PM
mchevy76
Feb 20, 2008 12:58 PM
denvermoe
Feb 15, 2008 02:43 PM
mdfloyd
Dec 6, 2005 03:29 AM
