< src="http://www.google-analytics.com/urchin.js" =text/> </> I was just wondering if anyone has has a problem with a high idle. I have a 2000 sl2 and when I go on a road trip sometimes my car wont udle under 1500 and there are no dtc so far I've cleaned out the throtle body and replaced the tps sensor and throttle cable. I hooked up a scanner to it and did a companant test and there are 2 coponants that are failing the test one of them is monitor id # 06 and monitor id # 30 I've been tryinh to figure out what they are with no success can anyone help?????? < =text/> _uacct = "UA-939292-47"; urchinTracker(); </> |
Try spraying some throttle body cleaner around the intake manifold gasket
to see if it affects the idle. The sl1 engines have a history with this. |
| All times are GMT -5. The time now is 09:57 AM. |
