-   -   2000 SL2: Check Engine Light (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/2000-sl2-check-engine-light-5268/)
Thisto Nov 29, 2010 06:42 PM
My check engine light came on and I went to get it checked at a Saturn dealership. They said I needed to replace the EGR valve, Coolant temp sensor & connector, and the thermostat.
I was wondering if any of these are absolutely necessary, or if I can test to see which one may be the real problem- I don't trust them since they also said I needed spark plugs and wires needed replaced and I just had those done less than a year ago.
Thanks.
derf Nov 29, 2010 07:01 PM
interesting -- no saturn dealerships left.......
go get the codes read at autozone or similar
post the actual codes (Pxxx) and we'll take it from there
and please no double posting
sw2cam Nov 29, 2010 07:07 PM
Yep the last Saturn dealer closed some time ago. Oh and by the way, no need to double post.
brags Nov 29, 2010 07:08 PM
i totally agree with you thisto." when you say i dont trust them "the dealer"
i no the feeling been there two two questions for you how does the car run?
and how if you no. how? did the tecnition test a faulty EGR,coolant temp sensor & why thermostat is it running hot?
sw2cam Nov 29, 2010 07:27 PM
No need to worry about trusting a Saturn dealer now brags ... they are all gone.
derf Nov 29, 2010 09:52 PM
oh -- and never ever go to a dealership at the end of the month -- the service writers are trying to meet quotas
