2000 SL1 Need help with headlight adjusters
Old Dec 17, 2012 | 10:01 AM
Alteran2003's Avatar
Default 2000 SL1 Need help with headlight adjusters
2000 SL1 I need to adjust the headlights. The adjusters for vertical adjustment are the ones I need to move.
They have a vertical shaft with a male torx head on top, the bottom of the adjuster is in a plastic housing that has a threaded shaft running horizontally to the headlight housing. This horizontal shaft is somewhat rusty although I can still clearly see the threads. I'v soaked it with PB blaster and it will move back and forth some but not freely. Is the bottom of the vertical shaft a sort of worm gear that is supposed to turn the horizontal shaft? Is that a plastic worm and likely to strip? I have been trying to loosen the horizontal shaft by gripping it on the end with a vice grip. I cannot use the vertical shaft to move the adjuster.
I either need to get this loosened up or get new parts. Any ideas?
Any aftermarket parts for the adjuster?
Thanks, Al.
Old Dec 17, 2012 | 03:12 PM
A quick stop at AutoZone (or some such), and purchase a Chilton Saturn Manual 62300. Cost about $25usd. Section 12 (chassis electrical system), page 12-9 addresses the procedure for vertical headlight adjustment, along with the care and treatment of the torx-head screws ........
Old Dec 17, 2012 | 03:18 PM
or you could just take the headlights out and see what you need to fix.
Old Dec 18, 2012 | 07:56 AM
I'm with sw2cam on this one. I'd remove the whole thing in order to figure out how it works.
Old Dec 18, 2012 | 04:10 PM
My thought is, he has the car, he has the headlight, he should pull out the bad one to see whats going on..
ad82e
Mar 26, 2011 09:40 AM
john33
Sep 25, 2010 06:27 PM
nlange
Sep 21, 2009 08:27 PM
Alex H.
Aug 29, 2009 10:18 PM
MLmom
Apr 8, 2008 03:08 PM
