-   -   2000 Saturn SL1 Body Control Module (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/2000-saturn-sl1-body-cntrol-module-1813/)
JohnR Mar 15, 2008 09:58 AM
I need to do some electrical troubleshooting and need to know the location of the Body Control Module on 2000 SL1 models. Can anyone help? Anyone know of a good source for wiring diagrams? By the way, both Haynes and Chilton are very deficient on this technical aspect.
Thanks, John
Low Saturn Mar 15, 2008 12:58 PM
I have the wiring diagrams for just about all GM vehicles. What exactly are you looking for the pinouts for?
#1 is the location of the BCM for all third generation Saturn S-Series
http://www.differentracing.com/mike/parts/bcm.gifEdited by: Low Saturn
JohnR Mar 15, 2008 01:59 PM
Mike,
Thanks for the BCM location information ... I'm tracking down an open circuit in the keyless remote system for the trunk lid servo. It works sporadically ... not a key fob transmitter problem either.
Can you email (pdf) the 2000 wiring diagrams for this circuitry?
Thanks, John
hodazio Nov 4, 2008 10:08 AM
Hello mike,i have some problems with my car alarm, and with the BCM can you send me de BCM wiring diagram for the 2002 Sunfire Vin F 2.2Lts Ecotec Engine. ?
i think its the same for the Cavalier
[img]smileys/smiley19.gif[/img]
TNKS...
Low Saturn Nov 4, 2008 11:31 AM
I''ll take a look when I get home from work.
Low Saturn Nov 4, 2008 09:58 PM
C1, Purple:
A1-A2
Not Used
A3
WHT
194
Door Unlock Control
A4
LT BLU
195
Door Lock Control
A5
BLK/WHT
56
Trunk Release Motor Control
A6
TAN
694
Driver Door Lock Actuator Unlock Control (AUO)
A7
LT GRN/BLK
394
Driver Door Jamb Switch Signal
A8
LT BLU
395
Passenger Door Jamb Switch Signal
B1-B7
Not Used
B8
PPL
1807
Class 2 Serial Data
Low Saturn Nov 4, 2008 10:00 PM
C2, Light Blue:
A1
BRN
Park Lamp Supply Voltage
A2
Not Used
A3
YEL
43
Accessory Voltage
A4
ORN/BLK
737
Rear Compartment Lamp Control
A5
BRN/WHT
230
Instrument Panel Lamps Dimming Control
A6
PNK
1200
Headlamp High Beam Signal
A7
YEL
1836
Security System Sensor Signal
A8-A9
Not Used
A10
ORN
1732
Courtesy Lamps Supply Voltage
A11
ORN
1440
Battery Positive Voltage
A12
ORN
340
B1
BLK/WHT
451
Ground
B2
LT BLU
1134
Park Brake Switch Signal
B3
Not Used
B4
BLK/WHT
1576
Rear Compartment Lock Actuator Unlock
B5
Not Used
B6
DK BLU
1201
Headlamp Low Beam Signal
B7
PPL
1807
Class 2 Serial Data
B8
PPL
1807
Class 2 Serial Data
B9
PPL
1807
Class 2 Serial Data
B10
ORN
1940
B11
BLK/WHT
251
Ground
B12
Not Used
Low Saturn Nov 4, 2008 10:03 PM
C3, Brown:
A1
WHT
156
Courtesy Lamp Low Control
A2
GRY
Instrument Panel Lamp Supply Voltage
A3
Not Used
A4
LT GRN/BLK
592
DRL Relay Control
A5
BRN
323
A/T Shift Lock Control (MMO Only)
A6-A8
Not Used
A9
BRN/WHT
1571
Traction Control Switch Signal (Pontiac)
A10
LT GRN
66
A/C Request Signal
A11
ORN
192
Front Fog Lamp Switch Signal
A12
PNK
39
Ignition 1 Voltage
B1
PPL
719
Low Reference
B2
BLK/WHT
151
Ground
B3
BLK
1835
Security System Sensor Low Reference
B4
Not Used
B5
DK GRN/WHT
1317
Fog Lamp Relay Control
B6
Not Used
B7
BLK
28
Horn Relay Control
B8
YEL/BLK
68
Low Coolant Level Indicator Control
B9
GRY
728
Security Indicator Control
B10
WHT
1459
Security System Sensor Supply Voltage
B11
PNK
849
Brake Fluid Level Sensor Signal
B12
LT GRN
80
Key In Ignition Switch Signal
James Stephens Feb 7, 2017 12:45 AM
Uhcm front harness pin out?
Please help
I have a 2001 sl2 autotrans
The underhood fuse box started smoking and when I inspected it I found out that a previous owner had butured the front harness.
I grabbed one from a pick n pull.
Thought I could pull the connectors out of the uhcm and crimp the new harness in.
Went to work and when I came back one of my kids had tried to help and now I don't know the location of each wire in the far left connector.
I'm in over my head and I think the only way im going to be able to fix this is if I can come up with a pinout diagram for the front harness .
Please tell me you have one or know where I can view one online.
Thanks in advance for taking the time to help out.
derf Feb 7, 2017 12:53 PM
Try using Google to search on the phrase
2000 saturn sl1 pcm wiring diagram
and rummage through the images that google pulls up in the image section of the results. Either that or get a Field Service Manual (a REAL Saturn one) off Ebay.
