I need to do some electrical troubleshooting and need to know the location of the Body Control Module on 2000 SL1 models. Can anyone help? Anyone know of a good source for wiring diagrams? By the way, both Haynes and Chilton are very deficient on this technical aspect.
Thanks, John |
I have the wiring diagrams for just about all GM vehicles. What exactly are you looking for the pinouts for?
#1 is the location of the BCM for all third generation Saturn S-Series http://www.differentracing.com/mike/parts/bcm.gifEdited by: Low Saturn |
Mike,
Thanks for the BCM location information ... I'm tracking down an open circuit in the keyless remote system for the trunk lid servo. It works sporadically ... not a key fob transmitter problem either. Can you email (pdf) the 2000 wiring diagrams for this circuitry? Thanks, John |
Hello mike,i have some problems with my car alarm, and with the BCM can you send me de BCM wiring diagram for the 2002 Sunfire Vin F 2.2Lts Ecotec Engine. ? i think its the same for the Cavalier [img]smileys/smiley19.gif[/img] TNKS... |
I''ll take a look when I get home from work.
C1, Purple:
A1-A2 Not Used A3 WHT 194 Door Unlock Control A4 LT BLU 195 Door Lock Control A5 BLK/WHT 56 Trunk Release Motor Control A6 TAN 694 Driver Door Lock Actuator Unlock Control (AUO) A7 LT GRN/BLK 394 Driver Door Jamb Switch Signal A8 LT BLU 395 Passenger Door Jamb Switch Signal B1-B7 Not Used B8 PPL 1807 Class 2 Serial Data Edited by: Low Saturn |
C2, Light Blue:
A1 BRN 9 Park Lamp Supply Voltage A2 Not Used A3 YEL 43 Accessory Voltage A4 ORN/BLK 737 Rear Compartment Lamp Control A5 BRN/WHT 230 Instrument Panel Lamps Dimming Control A6 PNK 1200 Headlamp High Beam Signal A7 YEL 1836 Security System Sensor Signal A8-A9 Not Used A10 ORN 1732 Courtesy Lamps Supply Voltage A11 ORN 1440 Battery Positive Voltage A12 ORN 340 Battery Positive Voltage B1 BLK/WHT 451 Ground B2 LT BLU 1134 Park Brake Switch Signal B3 Not Used B4 BLK/WHT 1576 Rear Compartment Lock Actuator Unlock B5 Not Used B6 DK BLU 1201 Headlamp Low Beam Signal B7 PPL 1807 Class 2 Serial Data B8 PPL 1807 Class 2 Serial Data B9 PPL 1807 Class 2 Serial Data B10 ORN 1940 Battery Positive Voltage B11 BLK/WHT 251 Ground B12 Not Used |
C3, Brown:
A1 WHT 156 Courtesy Lamp Low Control A2 GRY 8 Instrument Panel Lamp Supply Voltage A3 Not Used A4 LT GRN/BLK 592 DRL Relay Control A5 BRN 323 A/T Shift Lock Control (MMO Only) A6-A8 Not Used A9 BRN/WHT 1571 Traction Control Switch Signal (Pontiac) A10 LT GRN 66 A/C Request Signal A11 ORN 192 Front Fog Lamp Switch Signal A12 PNK 39 Ignition 1 Voltage B1 PPL 719 Low Reference B2 BLK/WHT 151 Ground B3 BLK 1835 Security System Sensor Low Reference B4 Not Used B5 DK GRN/WHT 1317 Fog Lamp Relay Control B6 Not Used B7 BLK 28 Horn Relay Control B8 YEL/BLK 68 Low Coolant Level Indicator Control B9 GRY 728 Security Indicator Control B10 WHT 1459 Security System Sensor Supply Voltage B11 PNK 849 Brake Fluid Level Sensor Signal B12 LT GRN 80 Key In Ignition Switch Signal |
Uhcm front harness pin out?
Originally Posted by Low Saturn
(Post 11183)
I have a 2001 sl2 autotrans The underhood fuse box started smoking and when I inspected it I found out that a previous owner had butured the front harness. I grabbed one from a pick n pull. Thought I could pull the connectors out of the uhcm and crimp the new harness in. Went to work and when I came back one of my kids had tried to help and now I don't know the location of each wire in the far left connector. I'm in over my head and I think the only way im going to be able to fix this is if I can come up with a pinout diagram for the front harness . Please tell me you have one or know where I can view one online. Thanks in advance for taking the time to help out. |
Try using Google to search on the phrase
2000 saturn sl1 pcm wiring diagram and rummage through the images that google pulls up in the image section of the results. Either that or get a Field Service Manual (a REAL Saturn one) off Ebay. |
