2 light questions re leds
Old Nov 1, 2009 | 09:30 PM
saturnsdn's Avatar
Default 2 light questions re leds
I'm thinking of switching to led lights in my car and had 2 questions.
1) I know the brake light/reverse number is 2057 and have only seen 1157s in led so can they be used? I assume yes but want to check first
2) does anyone know if the front sidemarker/plate lights bulb number 24 is available in leds? I've tried searching but only come up with string lights and common bulb styles that have 24 lights in/on it but nothing for bulb number 24
Old Nov 7, 2009 | 05:34 PM
saturnsdn's Avatar
no one knows?
Old Nov 8, 2009 | 02:17 AM
apparently not
Old Nov 8, 2009 | 09:10 PM
pain's Avatar
The 2057 and 1157 use the same socket, and the filament locations inside are the same. The main difference is the 2057 uses a stronger, heavier duty filament.
Old Nov 9, 2009 | 06:06 AM
I sit corrected. Apparently Pain knows. Actually you could look that kinda stuff up on your own.....
Old Nov 10, 2009 | 09:26 AM
saturnsdn's Avatar
I have done a search and didn't come up with any definite answers so that's why I asked. I knew the connectors looked the very similar but wanted to find out if someone knew they were the same. I'd rather find out whatever I can before doing something then go spend the money and find out it won't work and unable to return item.
Old Nov 10, 2009 | 09:12 PM
fair enough.
silver04saturn
Mar 17, 2010 04:16 PM
Dogberri
Aug 19, 2009 10:19 AM
Saturntuner88
Aug 14, 2009 11:55 PM
budsjlm
Tires
Jul 30, 2009 11:27 PM
rabobanks
Jul 7, 2008 09:10 AM
