-   -   1999 sw2 running rich (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1999-sw2-running-rich-3951/)
tfg11199 Oct 17, 2009 06:57 PM
I have a 99 sw2 that's driving me crazy. Picked it up with a blown engine, rebuilt the motor w/ new everything. started her up today and it ran as expected until it warmed up, then it seemed like it was getting to much fuel (kinda sputtering along at idle). I replaced the temp sensor with a good borg warner brass one, still no luck. If I let it cool down and start it back up it will run fine for the first 5 minutes or so then it goes back to a rough idle like it's getting to much fuel. any suggestions?
tfg11199 Oct 17, 2009 06:59 PM
Also upon inspection of the iac and throttle body it looks like someone had been tinkering with it before. so I suspect that the problem was there before I got it.
OceanArcher Oct 17, 2009 09:44 PM
Which temperature unit did you replace, the one for the inlet air, or the one for engine coolant?
