-   -   1999 SL1 Relay Diagram (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1999-sl1-relay-diagram-2639/)
henryj10 Nov 18, 2008 05:34 PM
Looking for a Diagram of the Relay box in a 99 SL1. Specifically looking fora relay for thefuel pump, for poor mans security system, SL1''s my woman''s. Got any links to diagrams, know of a relay that may help me, or arewilling to get your chilton out and take a picture of relay box diagramI''d appretiate it thanks.
Jason
Thanks
Low Saturn Nov 19, 2008 09:06 AM
Electrial diagrams for relays are usually printed on the relay. And most all automotive relays work the same. I think what you''re really looking for is a wiring diagram for the harness connector for the interior fuse panel. You''re looking for the wire that controls the fuel pump right?
henryj10 Nov 19, 2008 12:54 PM
I''m looking for a relay for the fuel pump to pull out so the fuel pump won''t work, when parked so the vehicle wont start. Its my gf''s car I''ma ford man,do it on all of my vehicles including toyota''s. Pull a relay out so car won''t start when its parked,not looking for wiring looking for a relay specifically related to the fuel pump, I''ve heard the starter relay is under the dash which might work but I''m looking for the fuel pump. Ford just puts all the relays in the relay box under the hood, these things it seems u have to hunt for them. Edited by: henryj10
OceanArcher Nov 19, 2008 01:27 PM
Hee hee hee - OK
The fuel pump relay is on the instrument panel junction block
Low Saturn Nov 19, 2008 03:02 PM
Only two fuse panels in the car. One under the hood on the drivers side behind the airbox and the other inside the car. Sitting in the passenger seat, its next to your left foot behind a removable panel. Just look on the panel for a fuse and relay diagram.
You seriously couldnt find it? It think it even says fuses or something on the outside of it.
Justin Gross Oct 6, 2019 09:28 PM
Maybe cause like me I bought the car and it didn't have the cover to the fuses so how will I find the relay now??
