-   -   1999 SL1 Door Lock (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1999-sl1-door-lock-492/)
NBR_JasonB Jun 17, 2006 01:15 PM
I have a 1999 SL1 and the drivers side door lock doesnt work with the keyless remote. I took the door panel off and I see the one end of the rod that connects to the door handle is attached but the other end is not attached to anything. I cannot see inside the door to reattachit so my question is, does anyone know what this reattaches to? Without being able to see inside the door I am trying to do this by feel but when I am not sure what I am looking for. Any help would be appreciated.
sw2cam Jun 18, 2006 11:36 AM
Once you remove the door handle,and the door skin you'll be able to see everything.First stop at your Saturn dealer to get the rod fasteners.
NBR_JasonB Jun 18, 2006 01:34 PM
Thanks for your reply. I have already removed the doorpanel but I still cant see inside to see what the rod attaches to. There is a plastic piece attached to the end of the rod but I cant see what it went into. Are you talking about the door panel or the actual inside skin of the door?
sw2cam Jun 18, 2006 02:00 PM
The outside door skin.............Lift the handle up and you'll see a small pin. Remove the pin, remove the handle. Then the door skin unscrews from inside of the door with TORX fasteners. Easy to do.
