-   -   1997 SL 1 idle sensore? (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1997-sl-1-idle-sensore-1394/)
robb Sep 26, 2007 03:42 PM
The car has 138000,Manual,2.1 liter?Would start car in morning and drive away.It started to stall out if I didn`t let it come up to operating temp and wouldn`t restart for 10 minutes.Noticed latley that the idle starts at 1200rpm and it hicups and stalls while comming up to temp and idle goes down.Thank`s.
01dbsc2 Sep 27, 2007 08:25 AM
what kind of saturn is this...2.1L
i know of the 1.9l (sohc dohc) the SC2.0, 2.2, 2.4 (all ecotaks)
id try cleaning my throttle body, and then cleaning the coil mounts (assuming this is an s series) fyi where they mount to the tranny. And inspecting your plugs.
robb Sep 27, 2007 01:36 PM
Sorry 2.0,was told to check the air idle valve on throttle body.
ducky Sep 27, 2007 04:58 PM
If you have the original engine coolant temperature sensor(ECTS) that tends to crack you'll need to remove it and check if its the plastic tipped one. Its the two-wire one and when it cracks it leaks coolant into the connector that corrodes it also. The two-wire connector then needs to be replaced, from eithera junk yard air temperature sensor connector or the dealer's $30 part. Although the engine seems to run at the right high idle when cold (1200 rpm) the coolant sensor may be damaged and inputting incorrect temperature information to the PCM affecting warm-up.
01dbsc2 Sep 28, 2007 11:20 AM
FYI the 2.0 iirc was in the ION REDLINE...which should be posted in the ion section.
robb Sep 28, 2007 01:04 PM
robb Sep 30, 2007 02:48 PM
Checked with code reader,no codes.Cleaned throttle body,So far so good.Runs smoother too.I might have got lucy,
sw2cam Sep 30, 2007 02:59 PM
the SC2.0, <-------------Whats that?
all ecotaks <-------------Whats that?
So Rob your saying you have a 2.0L supercharged ION Redline with a 138K on it?Edited by: sw2cam
01dbsc2 Oct 3, 2007 01:07 PM
sc2.0 is a SUPERCHARGED 2.0 in the ION REDLINE
ecotaks = ECOTEC, that thing thats under the hood of the ions
FYI LLO= Engine in the Sx2 Series.
robb Oct 3, 2007 03:35 PM
I`m sorry, it was wrong to be so general with my info.It was a 1997 5 sp with a 1.9. I think I came to the right place.Now,that code reader that I pu from a local parts store should tell me if a sensore goes?Thanks.
