1996 sw2 questions....
Hey guys, have a 1996 sw2 with 108,000 on it. Runs great, but have a couple questions.......
1 the temp warning light comes on randomly, then goes out??????? 2 what spark plugs are best, got bosch 4301's. 3 is the sub frame rusting out common on these cars, got it inspected and they told me that the driver's side sub frame was rusting out, will post pics tomorrow, but I don't see it. Maybe someone else can shed some light. thanks for all help, Chris |
Get plugs from the dealer, bring the bosch plugs back
Are you sure it's the water temp light not water level light Not common for the frames to rust |
no dealer in the area..... which should I go with?????
Plugs -- NGKs per owner's manual
If it is the coolant low light, you need to pull out the coolant reservoir and clean it -- the switch is at the bottom. If you're low on coolant to start with, you have bigger cooling system issues. If that does not work -- replace the coolant level sensing switch |
| All times are GMT -5. The time now is 07:46 AM. |
