The front windows in my SL2 tend to start rolling down uneven(especially in cold weather). In cold weather, it is to the point that they won't get past the first inch without help. Once past that point, it is fine. Is this a common problem on Saturns? What could be the cause of this problem? Thanks. |
YOU POSSIBLY NEED A NEW WINDOW REGULATOR Whats up with the large font anyway??? |
Actually you just need to put some lithium greese on the sliders that are sliding in the trackat the bottom of the window. You will need to pull the door pannel off in order to do this. I have recently done this to my 97 SL2 that had the same problem and now it works like new. Also take some vegetable oil and a q-tip and run the oil up and down the grooves that the window slides in. This will help get some of the dirt out. It will also help keep your window from freezing shut in cold weather.Edited by: answerman |
