-   -   1996 Saturn SL Over heating while idling (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1996-saturn-sl-over-heating-while-idling-7976/)
Vanderworkenm Jun 24, 2013 10:49 AM
I wouldnt say its a muddy milk shake but its not healthy looking either
OceanArcher Jun 24, 2013 08:24 PM
If you have one hanging above your workbench (compression gage), take it down, and run a test on your engine ....
Rubehayseed Jun 24, 2013 10:15 PM
What do you mean by it's not healthy looking? Do you have water bubbles on the oil dipstick? Maybe the coolant has never been changed. I'd recommend a flush of the cooling system and a fresh refill with a 50/50 blend of antifreeze and distilled water.
RjION Jun 24, 2013 10:49 PM
After checking the water pump for signs of leaking. After checking top drivers side of radiator on the engine side for swelling or cracking. Flush and refill .............. replace pressure cap.
If at one time someone replaced the ETCS with one from AdvanceO'ReillyZone you could very well be getting an incorrect temp reading at the guage, that also means your getting an incorrect signal being sent to the PCM.
Vanderworkenm Jun 25, 2013 02:42 PM
I plan on flushing it first thing in the morning, and by not healthy looking I mean it is brownish, and no I don't have a compression gage... today I turned the ac on so the fan would stay on and the temp. stayed right around the 3/8 mark like usual... Thanks for all the help you all have provided.
Rubehayseed Jun 25, 2013 04:54 PM
Yep, if it's brownish in color it's way past time to flush and refill the system. I think you'll see an improvement in the way it performs once you do this.
Vanderworkenm Jun 25, 2013 10:15 PM
okay that's good, yeah first thing in the morning im going to go ahead and do it... ill get back to you all with details of performance and what not after it gets flushed in the morning
keith Jun 26, 2013 01:59 PM
I hope you don't use any chemical flushes. If you flush, just use plane water, however, I would just drain and refill with fresh coolant at a 2:1 concentration with distilled or purified water, or use premix.
