-   -   1995 SL2 Steering wheel shakes (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/1995-sl2-steering-wheel-shakes-703/)
projectpete19 Dec 6, 2006 12:19 PM
Hello,
I just bought a 95 SL2 sedan, the car runs great until I go over 50mph. Once I go over 50mph the steering wheel will rotate from left to right about an inch every 5 seconds or so. Before 50mph the steering wheel is fine.
Do you know what the cause could be?Edited by: projectpete19
KLANDEFELD Dec 7, 2006 03:07 PM
have you balanced the tires? Or is it happening more when braking?
projectpete19 Dec 7, 2006 03:31 PM
no i havent done anything yet, no it doesnt happen when braking, only when going over 50mph. its like once the odometer hits 50 on the dot it starts
KLANDEFELD Dec 7, 2006 04:22 PM
Possible tire issue. I would try rotate and balance before any mechanical issues. Much cheaper way to start.....
projectpete19 Dec 8, 2006 02:32 PM
alright i will try that, thanks
Forgiven Dec 12, 2006 02:56 PM
I had a similar issue such as this and it ended up being a tie rod end. I never noticed it until the car got up in speed. Tie rods are simple to replace but you HAVE TO</span> have your car aligned after you replace them.
projectpete19 Dec 12, 2006 04:38 PM
how can i check myself if the tie rod end is bad?
Forgiven Dec 12, 2006 09:06 PM
Good Question.... I have tried and tried and without taking off the wheel and all that jazz.... it's a tough one (for me personally) ... I have seen people jack the car up and jiggle the tire and all sorts of things... But, Instead of doing all that I take my car into a place and tell em I want an alignment (front end - 35$ to 45$ usually) If the tie rod end is bad they can't do the alignment, the guy will come out and tell me the issues I have with my car (if any) and I end up doing all that work myself (Ball joints, Tie Rod ends, etc.) and then I end up bringing it back to them to have the alignment done.
** One ignorant thing I have done in the past is I bought brand new tires (450 bucks) and never bothered to get an alignment done (didn't think I needed to) and 5 months later my brand new tires were shot because I had a stinking tie rod end that was bad. I could have saved myself all that misery by just replacing a tie rod end for 12 bucks and getting an alignment. I'll never NOT do that again!
Edited by: Forgiven
