1995 saturn sl2 help needed
Hello my names Austin. I own a 1995 saturn sl2 dohc. i was wondering will a 1996 sl2 drivers side front fender, inner and steering/spindle knuckle fit on my 95 sl2. any help would be greatly appreciated. it
Post moved to correct location
96 was the 1st year of 2nd gen sedans, so tough to say. I use rockauto.com and more often gmpartsdirect.co to search by part name and grab part numbers. Once you isolate the part on the site, it will tell you at the bottom, which other years/vehicles that identical part number was used in. So start with your 95SL2, et the part num's, then perform the same search on a 96 SL2 |
(Post 56725)
96 was the 1st year of 2nd gen sedans, so tough to say. I use rockauto.com and more often gmpartsdirect.co to search by part name and grab part numbers. Once you isolate the part on the site, it will tell you at the bottom, which other years/vehicles that identical part number was used in. So start with your 95SL2, et the part num's, then perform the same search on a 96 SL2 Thank you for the help i just got off the phone with a local gm dealership they gave me a parts number and ill do your advice i greatly appreciate it man. |
