1994 SL2 dash lights
Hi all,
New to this forum, I have just recently replaced my instrument dash lights on my 1994 SL2. Works great now...but I now noticed that the speedometer needle,RPM needle, fuel gauge needle, temp needle, and battery charge needle are not lighted up during night driving. I can not remember if they did before, if they did what do I need to check to get them working again. Thanks for any suggestions. Brian |
Brian, check the fuses. There should be one for dash lights. Power to your dash lights in controlled through the dimmer switch. If you removed any dash trim and had to unplug anything, make sure you plugged it back in. Unlikely all lights are burnt out unless there was a short.
| All times are GMT -5. The time now is 03:40 AM. |
