1992 SL2 DOHC Belt or Chain?
Old Nov 12, 2008 | 09:59 AM
beardown's Avatar
I am in the process of selling my 1992 SL2 w/ DOHC. An interested party asked if I ever had the "Cam Belt" replaced and I asked if he was refering to the Timing Chain? He said he was refering to the belt. I need clarification on if this guy knows what he is talking about. I thought this model has a timing "chain" not belt. Also, is there such a thing as a Cam Belt? I also asked if he was referring to the Supertien (spelling?) belt and he said not. He indicated that most Saturn owers have the "Cam Belt" change around 100k miles. I checked with my mechanic and he said there is a time chain which is pretty much maintenance free. Does this guy know what he is talking about? Thanks.
Old Nov 12, 2008 | 10:46 AM
It is a chain.
DOHC, length 22.87 in to 22.99 in. Service limit is 23.15 in.
Unless I was hearing a definite rattle in that area, I would not worry about it, and even if I did, it might be the chain tensioner that was getting weak, not the chain itself
Old Nov 12, 2008 | 10:51 AM
beardown's Avatar
Thank you for the reply. There''s no rattle in the engine. The potential buyer was asking the questions over the phone prior to even seeing the car. Again, thanks for the info.
Old Nov 12, 2008 | 05:18 PM
Low Saturn's Avatar
If oil changes have been kept up and its never been run low on oil, the chain should last 300,000 miles or more. If its been neglected, 120,000 to 150,000 and the chain will be toast.
I just did a t-chain replacement on a 1994 SL2 with 120,000 miles on it. The tensioner was a full extension and the chain had stretched so much it ripped off the plastic part of the upper guide and bent the guide.
Old Nov 12, 2008 | 08:44 PM
Mike (LowSaturn) has said it all ...
There is no substitute for proper maintenance and service. Anything ignored long enough will break down ...
jstreeservice
Feb 25, 2015 11:38 AM
john doe
May 4, 2014 05:12 AM
wapayne
Sep 6, 2011 04:08 PM
ratattack
May 11, 2011 07:20 AM
Racemare
Jan 9, 2008 09:43 PM
