-   -   02 sl1 radio issue (https://www.saturnforum.com/forum/saturn-s-series-sedan-27/02-sl1-radio-issue-8926/)
02saturnsl1 Nov 10, 2013 12:11 PM
02 sl1 radio issue
i need the pin location numbers on the factory radio connector for a 02 sl1 with built in cd player, i already know what colors im looking for, i just need the pin numbers, i.e. b1, b2 a1, a2 those numbers only for the constant orange and the ignition yellow
OceanArcher Nov 10, 2013 04:50 PM
Chilton (among others) makes a Repair Manual for your car, and it is stocked at most after-market auto parts dealers. About $25 bucks last time I checked. It has a great electrical section which should answer all your questions about the connector wiring.
keith Nov 10, 2013 07:03 PM
Check this post.
https://www.saturnforum.com/forum/saturn-s-series-sedan-27/2001-sl-2-radio-wiring-diagram-7475/
The CD harness just goes from the CD to the radio, it does not connect to the car harness.
02saturnsl1 Nov 10, 2013 07:30 PM
2 Attachment(s)
i ment my radio has the built in cd player, ill include a pic and this is the harness i was talking about i need a pinout for
keith Nov 11, 2013 07:36 PM
The radio with the built in CD player is the same as for the radio with cassette tape or just the AM/FM radio only. The one that is different is the AM/FM radio with the CD changer. Then there is the same harness for the radio and a separate harness to go between the CD player and the radio.
But here is what you want in a different format.
A4 YEL IPFB-IGN .35
A6 YEL IPFB-IGN .35
A8 BRN LR SPEAKER .80
A9 YEL LR SPEAKER .80
A10 DK GRN RF SPEAKER .80
A11 LT GRN RF SPEAKER .80
A12 BLK SPLICE PACK #2 GROUND 1.0
B1 ORN IPFB BAT 1.0
B3 ORN IPFB-CD B+ .35
B4 GRA IPFB-DIMMER CONTROL .35
B8 TAN LF SPEAKER .80
B9 GRA LF SPEAKER .80
B10 LT BLU RR SPEAKER .80
B11 DK BLU RR SPEAKER .80
B12 BRN IPFB-PARK LAMP .35
IPFB Instrument Panel Fuse Block
The numbers at the end are the wire size in mm.
Top row, left to right B12 - B1
Bottom row, left to right A12 - A1
