01 saturn sl1
ok iv overfiled the ac freon came out the front of the compressure now the cooling fans and ac dont come on.
did i blow the ac compressure? all relays are fine so are fuses |
Need to borrow a set of gages from AutoZone (or similar) and check the pressure in the system. I suspect you blew out the safety plug in the compressor, but I'll entertain other comments ....
Happy Fourth of July to everyone ............ |
is that like a popoff vaulve?
Try a dictionary (plug, valve) not quite the same thing are they.
ok plug were is it at? and how do you fix it?
Fixed
Glad you got it fixed. What did you have to do? I don't know diddly squat about a/c.
A/C clutch cycle switch
Good to hear that is was something simple and not too costly. Thanks for letting us know. Every little bit of information we can get from other members may help someone else in the future.
| All times are GMT -5. The time now is 08:32 AM. |
