Tsb
Is there any way for me to tell if a TSB has been performed on my Outlook? I'm looking at the reflash... which is TSB # 08-07-30-022A which has to do with the reflash of the transmission shift points. I am actually the 3rd owner, so I have no idea whats really been done.
I get really bad gas mileage so I wonder if I need this done... Can a dealership just look it up and tell me if it's been completed? Thanks to anyone who replies! |
Call dealer with VIN in hand.
Thanks! I just made an appointment to take it in because it looks like I need the update. I'm in central michigan, so mostly flat. I averaged 16.82 mpg on 14,433 miles driven in 2013. Ratio of 50/50 highway to city driving...
Seems like it should be higher than that. Am I wrong? I am the 3rd owner now since it was new so it's tough to tell whats been done to it as far as the TSB's go... |
Cat, stop in the new member area and introduce yourself. When done open the USER CP and add your first name, location, and year/model to your "signature".
First you did not tell us the year or model "Outlook" your driving. AWD 3.6L should be around 18mpg. A FWD 3.6L should be around 19 mpg, and all of that depends on many variables. |
New member area? Signature?
Signature added and made post in new member area.
So I have a 2007 XE that's FWD 3.6. Had it at the dealer today, TCM needed an update. But good thing I had it in, cause they scanned and found the code that says the timing chain is stretched and are replacing all of that under warranty.
Warranty is nice.
