-   Saturn Outlook (https://www.saturnforum.com/forum/saturn-outlook-35/)
-   -   Camshaft position sensor bank 2 sensor 2 (https://www.saturnforum.com/forum/saturn-outlook-35/camshaft-position-sensor-bank-2-sensor-2-a-13695/)
Hamboned1 Mar 28, 2025 12:26 PM
I was looking for a wiring diagram wire color code for camshaft position sensors on a 2007 Saturn outlook xe 3.6
oldmarine Mar 28, 2025 12:32 PM
5V1 and Low Reference Bus section of this diagram: powertrain management electrical diagram
Hamboned1 Mar 28, 2025 12:44 PM
Ok thank you so much I am replacing the camshaft position sensor on bank 2 and have to replace the connector pigtail on it and making sure I have the correct wire color correct before I hook it back up
Hamboned1 Mar 29, 2025 07:50 AM
Ok I am having starting issues with this 07 Outlook , it will crank but no start, turns over good but no start, I replaced both camshaft sensors on bank 2 , and that code cleared only code i get now is a tunning valve code
grcauto8453 Mar 29, 2025 12:42 PM
And the code is??
Do we have spark and fuel?
derf Mar 29, 2025 03:45 PM
Please don't start additional threads with the same posts in them.
